Ah well, 4 days is still better than nothing :) I think I get Christmas til New Years off. Gonna be busy the whole time though. Wish I could just sit down and relax with a beer :P Would hit the spot.
Christmas is going to be a nightmare. Estimated travel In kms on 24/25 December: 500+
damn family livin in ballarat still :P
I'm driving to Adelaide after work on Friday :(
:rofl:
Jizz boy got a pay rise, or his "Band" must be kickin' off.
Haha, bit of a wanky shot but I wanted a pic with my plates in it. That's the first one I found.
That's when I was heading to DT Panels to pick up my car. Everything I needed right there :P The new plates and $2.9k cash.
And nah, band is only costing me money and I'm still on nearly minimum wage >_< Starting my business next year though. Then time for the cash to roll in!!!
Edited by jezza boii
:laugh: Cass!
What business you doing?
I want fitment like that.
You'd probably just need more low and a guard roll so no scrub on the side walls...
You could spacer out the rears a tad or just buy 2 wider offset wheels.
im driving to sydney tomorrow. dont ask why im driving
Why are you driving?
p's test in 2 days
im shitting bricks even though i can do everything right!
i hope i get a lenient examiner...
on another note, tried to changed the position of my boost sensor and ripped the plug that plugs into the back of the gauge clean off, went to pick it up, dropped it into a drain... f**king FAIL and a half
where to buy new plug..
p's test in 2 days
Is your gauge a racer series defi?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
