i got a GTS4 cluster, about 60,000ks on it
should work on gtr
Thanks but I want 300+ km/h cluster.
All the same, I believe.
Thanks, I'll try to grab one and see what happens.
I remember you can get 260km/h and 320km/h Speedos, either made by Nismo or HKS.
Or whatever other brand of aftermarket Japanese companies made.
Haha my Christmas pressies are being shipped off tomorrow, he won some items earlier in the week for me :)
Well alex, I'm trying lol manifold would have been great!!
Yer mirrors are on, should have a few new goodies next week! Then you must see my car!!!
niceeeeeee let me know im off work until next saturday doing sweeeeeeeeeet fk all.
Anyone got any r33 gts-t stockies or similar they would swap for 17" super advans? Plus maybe a bit of a cash difference.
Don't care about tyres. In fact, i'd prefer if they didn't have tyres at all.
Stockies are too useful to keep for clearing defects :P this I have observed, not personal experience. As per other thread I have no stockies.
On a lighter note I'm counting the days till I get new wheels XD
it's rather exciting
lol you managed to hit the armco changing from 1st to 2nd... what the hell do you wanna do 300kph for? ;)
fellas, 350Z rims on an r32 sedan,
thoughts/ opinions, or should i stick to 33 r rims. k go
33r on 32 = tuff
350z = fag
gtrs its not even a question slap yourself for asking.
this
What size advans do you have on yours atm cass?
Stock cluster isn't working 100% and I like 300 km/h cluster better.
And I want to bin the rsm while I'm at it
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
