i got a GTS4 cluster, about 60,000ks on it
should work on gtr
Thanks but I want 300+ km/h cluster.
All the same, I believe.
Thanks, I'll try to grab one and see what happens.
I remember you can get 260km/h and 320km/h Speedos, either made by Nismo or HKS.
Or whatever other brand of aftermarket Japanese companies made.
Haha my Christmas pressies are being shipped off tomorrow, he won some items earlier in the week for me :)
Well alex, I'm trying lol manifold would have been great!!
Yer mirrors are on, should have a few new goodies next week! Then you must see my car!!!
niceeeeeee let me know im off work until next saturday doing sweeeeeeeeeet fk all.
Anyone got any r33 gts-t stockies or similar they would swap for 17" super advans? Plus maybe a bit of a cash difference.
Don't care about tyres. In fact, i'd prefer if they didn't have tyres at all.
Stockies are too useful to keep for clearing defects :P this I have observed, not personal experience. As per other thread I have no stockies.
On a lighter note I'm counting the days till I get new wheels XD
it's rather exciting
lol you managed to hit the armco changing from 1st to 2nd... what the hell do you wanna do 300kph for? ;)
fellas, 350Z rims on an r32 sedan,
thoughts/ opinions, or should i stick to 33 r rims. k go
33r on 32 = tuff
350z = fag
gtrs its not even a question slap yourself for asking.
this
What size advans do you have on yours atm cass?
Stock cluster isn't working 100% and I like 300 km/h cluster better.
And I want to bin the rsm while I'm at it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
