i think i spotted you on dalton road yesterday, i was in the territory, rd p plates and personal plates
Yep, would have been me if it was around 2-3ish. My '33 has black wheels now. Was coming home from the parental's house in Preston. Temperature was so hot that me and the old man left work early for the day.
Didn't see you dude : (
$200 and you get 2nd one for free, alternatively, make an reasonable offer and you still get 2nd one for free.
haha ill take the 2nd one for my rb20dett O_o
Does it come with the holding bracket?
On another note; This is pretty cool if you want to free up space.
Yes both actuators does have holding brackets.
I actually thinking of buying this console so I can grab aftermarket gauges and place them on centre console and replace my a/c and heater panel which is semi-working.
Has anybody had any success using injector cleaner in the past?
I'm trying to eliminate a bit of a rough idle. Car has new coil packs but still isn't 100% on idle, especially when cold.
280rwkw. Everything hidden. Been pulled over atleast 5 times since it was built and Bonnet popped. Cop never found a thing :)
What turbo is it currently strapping to side of the 25?
Nope -7 and -9 (aka GT-SS) aren't the same, slighty different compressor wheel. -9 without EBC spools nice and early than -7 with EBC.
I wonder what would happen if I whacked EBC in my old 33 GTR and have it set up aggressively, I'd never know.
Yeah, the specs are not that far off from each other, but yeah I see where you are coming from.
Try living in Knox/Rowville area where Pettit advises all the Highway patrol people on what to look for ~_~
edit: didnt you get an EPA as soon as you got the car tuned?
whats the issue? Always stuck on blowing hot air?
Ambident temp won't stay on, a/c was working fine until some twat took the gas out to replace the heater system, etc...
So tempted to set it on fire.
That EPA was when I got pulled over before the car was built. Sent it in to get built and it was almost finished then got EPA in mail. Was costly but did have a atmo
Bov and 2 intakes n shit. Not anymore
Feel sorry for you Knox boys
AMB Temps only show for a few seconds and then turn off (in R32's).
Get the A/C re-gassed.
What useless piece of junk.
Still saying I shouldv'e bought a R33...
LOL!
Are you going to be staring at the AMB Temps as you drive..?
It's just to give an indication of how cold / hot it is outside...
^^ Yep!
haha why would you need to know the temperature every second? :P
Cuz Grant complains about stupid shit :rofl:
Grant don't worry about it!
You complain about your R33 and now your R32, just sell it and by a R34 GTR :D
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
