what do you wanna get?
Won't be getting anything for a while yet, but don't have a clue what I'd get...Nothing new really does it for me....
Few things that always cross my mind are 34 GTR, V35, 32/33 GTR...that's about it really...so who knows
Nice drive to Marysville today. 3 of us got pulling into drug bus in Lillydale. RX7, silvia and myself and didnt get defected, infact all the cops admired our cars and let us on our way haha best :thumbsup:
your lucky i got fkn :domokun: on toorak rd by a chick cop on those drug bus stations she was a fkn hooch and a hald kept me there for 15 minutes, wasnt int he skyline thank god..
V35 if you plan on supercharging/turbo charging it otherwise has to be a 34 gtr. personally i wouldn't spend 40K+ on a jap. some euro luxury/build quality would be nice for a change..
There's a few different things to consider before I chose obviously, but if I was spending $40k+, a lot more options start to present themselves
GTR would be mainly about performance, while still looking good
V35 would be more a nice cruiser first and foremost, but I only like them if done right, so it'd need to be low with a fair stance etc, supercharge/turbo would be nice but would probably be a longer term goal
euro, not sure what I'd get if I went down that path, but like I said, if you're spending 40k+, you'll have a bit more to choose from...
you'd want more for your money if you were spending that much i just dont think there are any jap cars old or new that offer a good all round package. 40k i'd go a bmw e46 m3 (if you want a straight 6) or audi b6 s4 (if you want a v8)without thinking twice coz it has everything luxury, performance, looks, quality etc. if you find a jap car for less than 40K with as much spec and goodies then by all means go for it
And the repairs/maintenance bills to go with it :P
that just depends on -
1) how much of a lemon you buy
2) how useless you are with tools
bout 40K for one with about 100Ks. pretty similar to 34 gtrs
id like to own a hsv coupe but they just aint worth the money people are asking for!
local spare parts, no cop hassles, v8 and a coupe!
Although people want like $50k for them!
coz one day they will be collectibles
you have a serious euro envy problem... just cos it's made in EU doesn't make it better than anything made in japan...
imho the onlymain thing the euro's do better than the japs is charge
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
