isf isn't that comparable to my 2.5ltr but yeh it drives nice, havent had any issues has alll the good features quality is good bit small would be my complaint but thats more for the back seat than the front.
lol, what's 10-4?
bed time? mine's 4 to whenever i want to wake up.
* 10-0 Caution
* 10-1 Unable to copy -- change location
* 10-2 Signal good
* 10-3 Stop transmitting
* 10-4 Acknowledgement (OK)
* 10-5 Relay
* 10-6 Busy -- stand by unless urgent
* 10-7 Out of service
* 10-8 In service
* 10-9 Repeat
* 10-10 Fight in progress
* 10-11 Dog case
* 10-12 Stand by (stop)
* 10-13 Weather -- road report
* 10-14 Prowler report
* 10-15 Civil disturbance
* 10-16 Domestic disturbance
* 10-17 Meet complainant
* 10-18 Quickly
* 10-19 Return to ...
* 10-20 Location
* 10-21 Call ... by telephone
* 10-22 Disregard
* 10-23 Arrived at scene
* 10-24 Assignment completed
* 10-25 Report in person (meet) ...
* 10-26 Detaining subject, expedite
* 10-27 Drivers license information
* 10-28 Vehicle registration information
* 10-29 Check for wanted
* 10-30 Unnecessary use of radio
* 10-31 Crime in progress
* 10-32 Man with gun
* 10-33 Emergency
* 10-34 Riot
* 10-35 Major crime alert
* 10-36 Correct time
* 10-37 (Investigate) suspicious vehicle
* 10-38 Stopping suspicious vehicle
* 10-39 Urgent -- use light, siren
* 10-40 Silent run -- no light, siren
* 10-41 Beginning tour of duty
* 10-42 Ending tour of duty
* 10-43 Information
* 10-44 Permission to leave ... for ...
* 10-45 Animal carcass at ...
* 10-46 Assist motorist
* 10-47 Emergency road repairs at ...
* 10-48 Traffic standard repair at ...
* 10-49 Traffic light out at ...
* 10-50 Accident (fatal, personal injury, property damage)
* 10-51 Wrecker needed
* 10-52 Ambulance needed
* 10-53 Road blocked at ...
* 10-54 Livestock on highway
* 10-55 Suspected DUI
* 10-56 Intoxicated pedestrian
* 10-57 Hit and run (fatal, personal injury, property damage)
* 10-58 Direct traffic
* 10-59 Convoy or escort
* 10-60 Squad in vicinity
* 10-61 Isolate self for message
* 10-62 Reply to message
* 10-63 Prepare to make written copy
* 10-64 Message for local delivery
* 10-65 Net message assignment
* 10-66 Message cancellation
* 10-67 Clear for net message
* 10-68 Dispatch information
* 10-69 Message received
* 10-70 Fire
* 10-71 Advise nature of fire
* 10-72 Report progress on fire
* 10-73 Smoke report
* 10-74 Negative
* 10-75 In contact with ...
* 10-76 En route ...
* 10-77 ETA (estimated time of arrival)
* 10-78 Need assistance
* 10-79 Notify coroner
* 10-80 Chase in progress
* 10-81 Breathalyzer
* 10-82 Reserve lodging
* 10-83 Work school xing at ...
* 10-84 If meeting ... advise ETA
* 10-85 Delayed due to ...
* 10-86 Officer/operator on duty
* 10-87 Pick up/distribute checks
* 10-88 Present telephone number of ...
* 10-89 Bomb threat
* 10-90 Bank alarm at ...
* 10-91 Pick up prisoner/subject
* 10-92 Improperly parked vehicle
* 10-93 Blockade
* 10-94 Drag racing
* 10-95 Prisoner/subject in custody
* 10-96 Mental subject
* 10-97 Check (test) signal
* 10-98 Prison/jail break
* 10-99 Wanted/stolen indicated
* 10-0 Caution
* 10-2 Signal good
* 10-5 Relay
* 10-8 In service
* 10-9 Repeat
* 10-11 Dog case
* 10-18 Quickly
* 10-20 Location
* 10-22 Disregard
* 10-33 Emergency
* 10-34 Riot
* 10-43 Information
* 10-70 Fire
* 10-74 Negative
* 10-89 Bomb threat
* 10-93 Blockade
* 10-94 Drag racing
tl:dr, summary please?
or mammaries please.
i like lexus, but they're boring to drive i heard.
compared to what?
mine drives nice goes well for a 2.5ltr 6 but no rocket i got sports model with "sports" suspension etc good fun with the paddle shifts in twsisties no 33 though if i wana go fast
IS350 = V35 350GT Sedan.
Just sayin. Wouldn't wanna own either.
That said, mate in QLD just finished putting a 2JZ (the VVTi single turbo version) into an IS250, still has to get it engineered n shit. Should be fun, might take it for a drive when I'm up there later this month. Watch this space.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
