Grant I think I'll be going with -5s once I got some cashola, I'd love a high mount but don't want the cop troubles - (more so I guess) anything above 350 awkw and I'll be happy obviously will be doing a lot of other stuff as well :D but just figured if I'm modding it I may as well make it worth while. Go for lots of power! you said you were bored of 300rwkw before remember :P
I was pleasantly surprised with -5s but it was with built motor and proper driver.
Now, my lovely next door neighbour is talking me into buying my old GTR (which is a wreck) and take some bits and put it into my GTR and sell rest of bits...
Rear end is good, interior apart from dash and airbags is good, motor still runs, have os triple, hks gt-ss, power fc, cam gears, I did 100k service, coilovers, BBS LM wheels.
These I can sell.
-5 i would say too grant...
Yes it would be good if you are flirting with power.
For street setup and response, you can't beat -9s (aka HKS GT-SS), fantastic turbos shame I never get to run one with EBC and set some gains blah blah blah...
You can get anal raped for no water in washer bottle these days... I also considered -5s but found T78 kit for 1500 but 2 blade shave slight chip so dunno.
Maybe I'll hit him up to check out his motor and take me for a spin.
Or I retune it and see if it is any better than before. If I change the turbo(s) it would defeat the purpose of me buying GTR with at least turbo upgrade in first place.
Lol true can get raped either way. Joshs car will soon get it's nismo afms. I'll get him to take you for a ride when it's pushing over 400awkw. It's on a conservative one at 343kw and they come on 21psi at 4500rpm. Running -5's
https://manage.crucial.com.au/cart.php?a=add&pid=114
they're giving away 300 lifetime free 100mb hosting based in sydney. use free subdomain to make it totally free. Not bad if you just wanna host some files or use it as an email forwarder etc. never know when you might need it. it's free anyways.
sweet thanks for that. Just signed up :)
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
