But it's an import. mine got rejected for being an import.
How do the ca's go?
ohh bot = not. lol pwnt. but anyways, all CA's are imports.
In fact, I'm pretty sure all S14's and S15's sold in oz are turbos. all the N/A are imports.
I'm 99% certain they put "Its cos it's an import" cos they couldn't legally put "it's cos you're arab" on your rejection.
ah yeah, true that, don't have to apply for exemption for that shiz.
CA18DE is gutless as fuck tho. As is SR20DE, RB20DE's not that bad cos you can rev it high all day every day and have good bottom end torque (being an i6), but SR and CA are both gutless down low and only good revving high. Oh and stock SR's tend to shit themselves when constantly revved high.
I'd buy an NA R33 if I were you. RB25DE is a good engine for an N/A. Just harden up and put up with the R33 body shell.
Failing that find an R32 GTS25, but good luck, they're few and far between.
Orrr... find a R32 GTS with the engine on the way out and swap in an RB25DE. Pretty straightforward swap (you can do it in a weekend) and also don't have to get it engineered.
No they don't - not if it's an engine that's available for that model car. Already asked vicroads about dropping a sr20det into GF's silvia back when she was still on Ps
"Replacement engine is identical to the original engine, or is an
option allowed by the manufacturer for the same model vehicle
The optional engine must be offered in Australia by the vehicle
manufacturer as an option for that vehicle (or certified variants). The
change of engine may be recorded by VicRoads provided that the
registered operator or a motor mechanic, or dealer in that make of
vehicle or an Automotive Engineer signs a declaration certifying the
engine is optional for the vehicle model, and that all modifications
made by the manufacturer for the same vehicle model with that optional
engine, have been completed."
yeah if it's a factory option then it's all good, hence RB25DE (not RB25DET). You don't even have to upgrade the brakes, cos they didn't change em in the GTS25.
meister S1 3pc. was gonna chuck em on the 32, but now they're goin on the 240z (once I do the S14 drivetrain conversion). 3.5k cos I don't wanna sell em :P but if anyone's tarded enough to give me that much for em, then I'm not gonna hold darwinian theory rob a fool of his money.
whats the specs? meisters wont suit 240z
What about the hubs? I don't want 4 stud herpies
your never going to have sex so dont worry your safe from herpes, unless of course your into underpant sharing.
It's all the rage these days
Fuuuuuuuuuuuuuuuuuuu stupidest thing I have ever done. Ever
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
