But it's an import. mine got rejected for being an import.
How do the ca's go?
ohh bot = not. lol pwnt. but anyways, all CA's are imports.
In fact, I'm pretty sure all S14's and S15's sold in oz are turbos. all the N/A are imports.
I'm 99% certain they put "Its cos it's an import" cos they couldn't legally put "it's cos you're arab" on your rejection.
ah yeah, true that, don't have to apply for exemption for that shiz.
CA18DE is gutless as fuck tho. As is SR20DE, RB20DE's not that bad cos you can rev it high all day every day and have good bottom end torque (being an i6), but SR and CA are both gutless down low and only good revving high. Oh and stock SR's tend to shit themselves when constantly revved high.
I'd buy an NA R33 if I were you. RB25DE is a good engine for an N/A. Just harden up and put up with the R33 body shell.
Failing that find an R32 GTS25, but good luck, they're few and far between.
Orrr... find a R32 GTS with the engine on the way out and swap in an RB25DE. Pretty straightforward swap (you can do it in a weekend) and also don't have to get it engineered.
No they don't - not if it's an engine that's available for that model car. Already asked vicroads about dropping a sr20det into GF's silvia back when she was still on Ps
"Replacement engine is identical to the original engine, or is an
option allowed by the manufacturer for the same model vehicle
The optional engine must be offered in Australia by the vehicle
manufacturer as an option for that vehicle (or certified variants). The
change of engine may be recorded by VicRoads provided that the
registered operator or a motor mechanic, or dealer in that make of
vehicle or an Automotive Engineer signs a declaration certifying the
engine is optional for the vehicle model, and that all modifications
made by the manufacturer for the same vehicle model with that optional
engine, have been completed."
yeah if it's a factory option then it's all good, hence RB25DE (not RB25DET). You don't even have to upgrade the brakes, cos they didn't change em in the GTS25.
meister S1 3pc. was gonna chuck em on the 32, but now they're goin on the 240z (once I do the S14 drivetrain conversion). 3.5k cos I don't wanna sell em :P but if anyone's tarded enough to give me that much for em, then I'm not gonna hold darwinian theory rob a fool of his money.
whats the specs? meisters wont suit 240z
What about the hubs? I don't want 4 stud herpies
your never going to have sex so dont worry your safe from herpes, unless of course your into underpant sharing.
It's all the rage these days
Fuuuuuuuuuuuuuuuuuuu stupidest thing I have ever done. Ever
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
