It's because you knew it would eventually happen lol. I'm waiting for it too. My guess mine will blow when the new turbs goes on
yup... yours cant hold up to what you have planned for too long
my old head chef (queenslander) used to always use as much water as he wanted... just leave the tap running while he walks away to do other stuff, hosing his lawns, car etc...
i always used to tell him off and turn the tap off saying "we're in a drought remember"
he would always reply "i dont give a fuck, there's plenty of water in queensland"
yeah cheers man
I'm always down for a cruise :D
Haha that's the spirit. I think I saw you driving through Mentone the other day with your L's up. Will be a good to see a nice red P plate instead soon :thumbsup:
and you think non turbo skylines aren't boring?
get a car that's meant to be NA
any vtec honda over any non turbo skyline anyday
DC2R > N/A Skyline and will give your turbo skyline a run for its money through the twisties.
Their power/weight ratio is 130kw/tonne, more than the r32 coupe gtst (125.1kw/tonne)
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
