juliette do you ever look at an FJ40 and feel unoriginal?
BAZINGA!
Damn, LTHLRB's MK3 golf has got the same size engine as mine (2L SOHC), cept mine's got full EFI, leather seats, cruise control, is 7 years newer and cost me $600 less.
Smart move would be to sell the golf for mad profits instead of modding it, instead of spending twice what I paid for it in mods.
What kind of power numbers would I roughly be expecting with the following mods?
full exhaust with aftermarket dumps / high flow (decat)
pods / CAI / box
cam gears / cams (tomei?)
-5s
new fuel pump / injectors / 98 ron
power fc / status tune
would i need a new cooler as well?
oh and also spitfire coilpacks
just looking for rough number to know if i need to put more on my shopping list which is slowly getting ordered :)
Useless with dash 5 without a rebuild because you will blow the engine sky high. And if you want like 300kw you will have lag upto 4500rpm. With a proper engine you should get in the vicinity of 380awkw
pods / CAI / box
-5s
1. do you have a job?
2. if no, do not pass go, do not collect $200, do not purchase mods for your car.
not at the moment Shan, but already got half the things in my closet and obviously not getting work done till i get a job / finish list off.
And yeh Kris dont mind a bit of lag, once your out of first / hard launch all good anyways :P figured cams will help out a bit as well
lol @ sam trying to convince someone that an auto to manual conversion on a GTS4 isn't that expensive.
you only need to change the front and rear diffs so the ratios match the box, and the only manual AWD boxes you can get came on manual GTS4s and GTRs, which are both way more expensive than a GTSt box.
yup, definitely a cheap job.
totally.
lmao, my mates cousin offered me a kia rio + 1k
so true
And another, because I think this one is deserved :nyaanyaa: haha sorry Mohsen :P
so true! made my morning haha
im quite liking going over speed humps at 20kms at the moment, if i did that in the taxi i would fly out the window
    • Had a chat to Tony Mamo - he advised that looking at the graph's shape (regardless of number translation) it shouldn't be levelling off like that up top. He said it looks like the car is running a restrictor plate or something of that nature. Luckily the last dyno pull on E85 was saved to the PC - So I did a quick trace of Barometric KPA vs Intake manifold pressure, and lo and behold I see a copy of the 'waves' I was seeing on the dyno: I'm not entirely sure how to go about addressing this. It may be worth sacrificing IAT to run a more direct intake for the motor. Though packaging this could be flat out impossible given the constraints of the car. I should have removed the intake pipe to see if this made a difference but looking at this graph I now have something to potentially test in the future and think about. This one is from an old track day log in the OLD setup going through gears on track.
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
