senator kinda looks like ass if you ask me. I'd buy a calais and bring in pontiac G8 kit from the US and slam it on 22's.
bogans will all be mad jelly.
  • Nope 1
yeh i really dont rate fords i just dont like the look, spose its true what they say your a holden or a ford man. having said that i loved the BA its just the new range dont rate.
x5 is still an option but i think i will be bored driving it day to day.
interesting, I've always been ford, the BA was a welcome sight from the AU obviously (although I do rate the look of a TS50), but imo the FG is just another step up from the BA looks wise...the head and tail lights just seem to work perfectly, and the performance models can look off their dick.
in fact, buy my brothers car...power and luxury, just what you real estate types need
  • Like 1
yeah FG's can look porn done right, the F6, black on black, ducktail spoiler... which is basically what my brothers G6ET is, XR6T with all the luxuries, ducktail spoiler and 19's...
VE's, not really a fan, but the high end ones like the GTS etc where the tail lights get changed, they can look alright
  • Like 1
Ford high tech suspension:
vs
Holden high tech suspension:
VE has better suspension geometry, not something that looks like it belongs in a 67 mustang.
Dirty kents at Ford call it "Control Blade Independent Rear Suspension" and try and peddle it off as something good. fuck off with that neolithic cuntbaggery, two leprechauns swinging off my nuts will give me more stability than that shit.
lol @ Nissans being more high tech than both by 1989.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
