Woah nice pix Jameh ... do want
:D
I still think Mine's have 1 of the most impressive VR38DETT.
" A motor built for response and unsurpassed in gear acceleration thanks to lighter engine components and an original turbocharger kit."
I like TRUST's FMIC.
Ok so for this week, spend $400.
Space yourself out another week or 2, to get some funds and spend $500 on GTR.
Done.
Thats the plan really, gonna get the rona done then look at my funds for another week got rego and rent coming up tho that will be 1k together mmm but should be able to get the gtr happy again in the next month :D
It's not a Porsche lol. You can do nearly anything to an MR2 without taking the engine out.
true, you can burn an MR2 without taking the engine out.
I'd probably take out the power steering though. shit's more valuable than the car.
Exhaust noise:
The vechicle was observed in PRINCES HWY, SPRINGVALE at approximately 12:18am on 15 January 2011
Remind me to never go to the hwy again, just a pain in the ass.
First EPA though so meh not bad for 8 months.
Anyone have a stock exhaust? or know if a 33 GTST exhaust will fit a GTR? cos then i can just borrow my brothers
Power steering is gay. If I had it, you could take it. But I don't :)
How about supercharged V6 rear engine for torque and skidz, and a massive turbo 4cyl up front so once the car gets moving you get high range power? :P Probably wouldn't work like that but I can dream lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
