Lol president-burn.
Ey jizzy you work near dandenong yeah? I just had lunch in the plaza, man there are some strange people there
Yeah, I work just near there. I was just having lunch at the plaza too :P Always lots of mental people and druggies talking to themselves etc.
It's good entertainment :)
not looking forward to my 2 bottoms to come through, 2 tops are through thank f**k
I had 3/4 coming through at once, pain for years until I got pissed off and had all 4 taken out at once. Worst pain ever but it ends up being worth it.
For realz. Shame i don't wear any of that stuff
Should have talked to her anyway :P And +1 for not wearing that stuff. Overpriced AND makes you look like a teenager.
Edited by jezza boii
did you do somethign about it ? or did u look at the floor wait to you were past her and be all "whip out my phone and tell wasteland a hot chick eye f**ked me" hahah :laugh:
bahaha that's exactly what i did :blush:
car all tuned now, 280rwkw. U mirin falcodore drivers?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
