^ lol haha
Grant - what's the cheapest you'll sell your seats for? PM me if you like... Mates rates haha
Which one? I'm also selling stock pairs and I've got someone coming tomorrow night for the recaros
So is he picking them up tomorrow or just having a look...?
He is going to grab them but if it falls through, I'll shoot you a pm.
Dezz, was it aimed at me? If so, care to explain?
sounds relatively easy
R-spec is yours tucked up as much as it can be though?
any higher and the tips would be touching the rear bar and melting it. the rest looks like it could go up a cm or 2 though
I will if they like it :)
good girl
$1200 but some bloke offered me $900 pick up
i was gonna offer you $600 just for the passenger side back when i enquired about them, but you didn't wanna seperate :)
Great, some q's for you.
What sort of degree do you have?
To make a edge out of competetiors (When lining up for job interviews), what additional degrees would be handy?
Typically, how many hours in TAFE/Uni do you attend?
I could ask TAFE/uni these sort of q but they'll just lie to get numbers so I'd better off ask someone who have go through it.
if you didnt do yr12 and are mature age, you will need to do a special test to determine your english/maths skills. If you pass that, then you can get into a degree. If you fail, you gotta go to tafe. However they may also require a test too if you didnt complete yr12.
Re; Accounting. Dont expect to finish a degree in Accounting and everything will work out. You will still need to do a CPA or Chartered Accountant qualification to get anywhere.
grant think the fees for non hecs student is just above 1k a subject...u got 4 sub in a sem and 8 a yr.... requirements will be diff for mature age...ill be in swinny on tues..if i remember ill pop into the business faculty and if they open get some info for you :)
Incorrect pat. Once you get a graduate position your employer will pay for you to do your CPA
yes thats if you get into a graduate position. Im sure you know how hard it is to lock in a grad position when HR is making the calls. We also talking about mature age student here. Who isnt going to be living off a grad salary. NFI on HR's view on mature age students as graduates.
My mum studied accounting degree as mature age student. Finished degree, found an accounting job and was funding her own CPA qualification.
The truth is, If it aint a grad position, everyone else will be asking for CPA qualification.
Question for Alex / Billy:
Have you got any pics of your exhaust like underneath? thinking about going dual tips a bit like you guys cos it looks bad ass from the Tuesday meet pics, and also the other reason is so I can lower it a bit more without this HKS thing almost hitting the ground it hangs so low. Any info would be good cheers :)
:cheers:
ill get a pic of under for you if you like ive had whole exhaust tucked cos a defect previously basically rattles against car sometimes but defs no clearence issues my sideskirt, front bar are the problems
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
