Wait till tomorrow night when your balls fall off and you choose not to go again.
lol i gotta drive to carlton to enrol in uni tomorrow ;)
aye hamish wanna lift with me from the meet point? more than welcomed to drive my car so i dont have to shit myself for 5 hours :)
This was a few years ago, thats what manual / coupes were going for stupid i know. Had a lot of good things that came with it though.
i sold a 1993 r33 gts4 automatic for 9K ~4 years ago
well thats cos the parts are still new my wing mirror cost 2k for one 1200 for the plastic shit and 800 for the heated glass stuff... headlight was 3k.. *shrug* car companies dont make profit on cars any more (apparently) they make it on the parts
>_<
rip off. im kinda having second thoughts on the whole car. plan B would be a 34R easier to work on and not as expensive to run (athink). but cant justify paying 40-50K for a car that looks pretty much like what i have now..
hmmmz
Drifteks have a less aggressive angle and the spokes are different
Uras have agressive spoke angle which does not change on width of rim
Rota nfi
Bee*r have win spoke angle
lmgt's have more curved edging to spokes and angle changes depending on width
serious buziness
Cant find a 9inch pair of Uras so will probably have to opt for some rotas :(
Only 4 door 32 ive ever liked was Nick's old car. Thing was neat and subtle.
As for getting pulled over, wrong place/time you'll always get done, doesn't matter how you drive. Having a black, white, silver etc car also helps cos it doesn't catch the copper's eye as much as something like bright red...
:wub: yeah it was alright
on my p's got pulled over like 30 times current car doesnt get driven enough but been pulled over once got 1 defect i dont agree its "how you drive" depends how stock your car looks
i dunno.... both my cars looked like easy targets to pickup and i hardly every got pulled over, and if i did i was always let go
If I drive in the same direction as a cop I will get pulled over. No doubt about it. I don't give a suit anymore Neways because I know they are too dumb to find any mods/defects :)
some are but you will find some that will defect/epa you
it's cos cops don't like your drifteks pat
lol
tommy mak
worst looking evo out of all of them
agree. normal evo 6 in blue/black = win
Yeah agree, Im actually not a fan of 6's at all
i prefer the 5's... they have a more aggressive look to them
Rota nfi
serious buziness
Rota's arnt all that bad.... check my grid's they have fairly tuff concave on them, for cheap rims
>_<
hmmmz
auto plus most people had turbos back then on Ps, and a 93, I bought a 93 4 door auto for 8k when i first got Ps, f**ked it up and got a 2 door coupe manual for extra 3k but was 95 and much nicer accessories
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
