Wait till tomorrow night when your balls fall off and you choose not to go again.
lol i gotta drive to carlton to enrol in uni tomorrow ;)
aye hamish wanna lift with me from the meet point? more than welcomed to drive my car so i dont have to shit myself for 5 hours :)
This was a few years ago, thats what manual / coupes were going for stupid i know. Had a lot of good things that came with it though.
i sold a 1993 r33 gts4 automatic for 9K ~4 years ago
well thats cos the parts are still new my wing mirror cost 2k for one 1200 for the plastic shit and 800 for the heated glass stuff... headlight was 3k.. *shrug* car companies dont make profit on cars any more (apparently) they make it on the parts
>_<
rip off. im kinda having second thoughts on the whole car. plan B would be a 34R easier to work on and not as expensive to run (athink). but cant justify paying 40-50K for a car that looks pretty much like what i have now..
hmmmz
Drifteks have a less aggressive angle and the spokes are different
Uras have agressive spoke angle which does not change on width of rim
Rota nfi
Bee*r have win spoke angle
lmgt's have more curved edging to spokes and angle changes depending on width
serious buziness
Cant find a 9inch pair of Uras so will probably have to opt for some rotas :(
Only 4 door 32 ive ever liked was Nick's old car. Thing was neat and subtle.
As for getting pulled over, wrong place/time you'll always get done, doesn't matter how you drive. Having a black, white, silver etc car also helps cos it doesn't catch the copper's eye as much as something like bright red...
:wub: yeah it was alright
on my p's got pulled over like 30 times current car doesnt get driven enough but been pulled over once got 1 defect i dont agree its "how you drive" depends how stock your car looks
i dunno.... both my cars looked like easy targets to pickup and i hardly every got pulled over, and if i did i was always let go
If I drive in the same direction as a cop I will get pulled over. No doubt about it. I don't give a suit anymore Neways because I know they are too dumb to find any mods/defects :)
some are but you will find some that will defect/epa you
it's cos cops don't like your drifteks pat
lol
tommy mak
worst looking evo out of all of them
agree. normal evo 6 in blue/black = win
Yeah agree, Im actually not a fan of 6's at all
i prefer the 5's... they have a more aggressive look to them
Rota nfi
serious buziness
Rota's arnt all that bad.... check my grid's they have fairly tuff concave on them, for cheap rims
>_<
hmmmz
auto plus most people had turbos back then on Ps, and a 93, I bought a 93 4 door auto for 8k when i first got Ps, f**ked it up and got a 2 door coupe manual for extra 3k but was 95 and much nicer accessories
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
