I'm just pissed off, have been all day!!! f**king shit f**k ahhhh happened last night leaving my gf's. Reversing out of the stupid altona meadows driveways. Tyre pulled it in nice, having no luck fixing it atm :( now it just looks ridiculous, I've made a mess of it!! Sigh
know exactly how you feel. only my tyre pushes the lip out while getting in our driveway and i have to push/roll it back in. then i go cursing everyone who's parked their car within 50m of our house for not giving me enough space to do a 11ty point turn to get the car in right without rubbing the guard :/
And there's me getting quotes for 265 fronts and 285 rears LOL yer for sure
wtf you want tyres like that for?
oh wait haunted hills ?
get ya primal mates to fix it for ya cant be beyond repair if it is i picked a rear bumper up last night off a guy in balwyn parting out a white 33 had front guards there i could see
So I can go faster around corners! Lol
It's pretty f**ked, see how I go tonight. It looks like ass but as long as it's not touching I don't care!!
That would be handy. Can't imagine what it would look like though.
In other news, going to check on my car on Friday. Too excited :) not done yet but close-ish!
Can't wait to ditch trains every morning!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
