holy fkn shit, just drove to/from the city in this rain. So many roads flooded, cars floating, accidents. Cant see shit.
First time driving in this kind of weather. (L's)
Was on a highway, it was soo heavy i couldn't really go over 50. Meh.
yeah all ok but the roof caved!
SHIT! sorry to hear!
okay went back and had a good look over that black r33, under the drivers door i noticed some faded paint, got the magnet out, yup
bog. walked away....
sarumatix plz buy my car :P gimme an offer >_<
Ohay mohsen. Buy this! It's in shepp.
http://carsales.mobi/cars/details/?R=9826138&Cr=1&trecs=2
price and reg are right. Non turbo is right. MANUAL is right!
Found it while trying to convince my sister, who does like skylines, to buy one...instead of a mini which for some reason she likes more
/facepalm
anyone flood?
nope, but have a massive amount of water coming down the hill - flows around the house though thankfully, rather than through it
crispy what happend to your gearbox? (too hard to scroll back sorry)
diff collapsed.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
