go to hillside exhausts in furntree gully they have a $100 thing where they put temp exhaust on you go clear EPA, then they wack your old system back on :) they had a 32 exhaust i think, but had to slightly modify it to fit my 33 but because jay is a champ didnt charge me any extra
SWEET.
So taking immaculate conception into account, and IVF
It's possible ye?
what are you on about?
lol, their car got trashed and they offered me a reasonable price for my car so yeh, just need to remove the boost tee and get a new bonnet lever handle for road worthy.
is that the one were he breaks his leg tryina kick down a tree? lol
that guy was and pretty much still is my idol eventhough he cant act
That's the one...cuts it to the bone, don't think it's broken though coz he keeps walking/fighting
Was trying to find racepace today.. driving down the road.. where is it? oh 10 gtrs right there out the front.. i figure that must be it :D
Got quoted about 600 for 100k service with cam gears put on (with my parts I already have) water pump fuel filter and all the shit. What you guys recon?
www.revzone.com.au for a second quote.
Did my 200k service. I was down there last week and they had a r35 GTR with the engine pulled out. Engine has to come out when upgrading turbos as the manifold is attached to the turbos
Just to clarify, the bonnet latch handle in he r32s, is It one piece from the front of the bonnet to the cabin? Or can I undo It and buy a new handle.. Need one for road worthy..
bonnet latch is attached to the cable. You would need to replace the whole cable i believe. Someone snapped the plastic handle?
ffs, theres a nut before the cable, tighten the tension?
looks like ill be going to jap heaven this weekend, oh joy
did you replace it??
i dunno why they have to be oem, i had a look at the handle when it snapped and their weak as shit, so i made a stainless steel ring that i would weld onto the pin that the handle sits on. but noooooo has to be oem
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
