harsh lol :laugh:
Fixed back for track days etc takes 10min to put old seat back in... I have never moved my drivers seat in 5 years of owning my car for someone to get in lol f**k that, go around!
oh fair enough but still easier to clean around if you can move it lol
yeah coz easier access to the back seat is girly/muztek...
I don't move my driver seat. Ever. Get in through the passenger side, its got a lever and slide mechanism for that.
Dunno why anyone in their right mind would put a fixed back on the passenger side. It's not like you're going rally driving and have a navigator all the time.
re; house auctions.
If you win a house auction, is it pending finance approval? Or is the winning bid locked in and you forced to pay?
I know private sale of houses can be put on hold subject to finance, but is this the same for auctions?
cheers
No, auctions are unconditional (ie you can't say "subject to...finance/building inspection etc."), you bid you buy (or come to some arrangement to cover costs and time wasted)
re; house auctions.
cheers
called the realestate agent to ask if i need a pre-approval and he said nup, just show up on the day and bid away. Didnt ask him about bid being subject to finance though, so wanted to know if anyone knew.
Wont get a pre-approval before Sunday and the auction is on then :(
yeh auction is unconditional not even cooling off period applies. pre approval doesnt mean jack for whats its worth i can put you in touch with people who can basically tell you on the phone if its ok or not for you to buy at a set price provided you give them the accurate answers to the questions they will have.
ive sold properties to ppl with pre approvals that then got declined its a bit of paper you may as well wipe your ass with.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
