I had a plan years ago to buy a cheap little laser as a daily when I had my 33.....was gonna paint the whole thing like lime green with spray cans, black bonnet and wheels (with spray cans...)...never did get around to it though
Lol me and my mated wanna buy old school civics and just smash into eachother at red lights and shit (top gear styles). Would make people go WTF haha
I think half the world already knows :P
That said, i knew last week if we are playing 1-up lol :D
Pfft i dont, who was it?
You can get fined for that
careless and reckless driving
Sending my iphone 4 back to vodafone because i've gotten out of my contract and they're shit.
Want to take a ipad or something overseas so I can access wifi and keep in touch with home. Anybody know of any good tablets (preferably other than ipad) that I should look into buying?
Prefer cheaper so that if it gets stolen / broken i will only give 0.5% of a f**k.
Motorola Xoom: http://www.google.com.au/search?sourceid=chrome&ie=UTF-8&q=motorola+xoom
HP TouchPad: http://news.cnet.com/8301-1035_3-20031203-94.html
real estate agent said 270 - 300. Ended up going for $332.5
Decided to change my view and look for 2 bedroom appartments. Smaller deposit and no issues with the 50sq metre loan rule
btw; do you know any website which lists recent auction sale prices? Interested in chasing up some auctions i missed out on.
Thanks!
re; web hosting and website address.
http://www.jumba.com.au/hosting/personal
Let me know if you need any help
yeah sounds about right for auction 10% approx over, keep in mind agents/sellers have a 15% leeway on auction which is a pain. I'd suggest sunday papers im not sure where else the info is available free. Agents subscribe to services for sale prices etc. To be honest the agent shouldnt have much issue telling you buyers are thin on teh ground so get in with a few agents well and they will look after you well and hook you up. pm me the address if you want i can try run em see if i get anything
Unless the house is covered by a Heritage Overlay, you can essentially paint it whatever you like.
When I was working in the industry, I once got a few phone calls from a resident who was complaining that their neighbour had painted his house fluoro pink. Turned out to be a neighbourhood fued escalating, and because the caller sounded like such a bitch, I took great satisfaction in telling her that there was nothing I could do about it : )
yeh or body corporates can be super strict
Yeah I know, just that I'm tempted to say something now so that it doesn't delay the finish date more than it needs to...re-painting is easy enough, but re-plastering etc is a bit more work... not 100% happy with the tiling in some spots either, doubt they'd re-do that though :S
yeh tiling not likely unfortunatley, whose building it? You can tell em they might tell you why you on site its not allowed blah blah lol
the tiling isn't a major issue, but I'll still mention it..
the site manager has been alright with me since the start, knows I've got my construction white card etc and he's let me and mates on site earlier to do work before plaster etc went up...
Already thought about what I'd say if I mention it before final inspection, was just gonna say I went to check it out and the garage door was wide open, so I went in to see if anything had been damaged etc...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
