its a nice looking car, but its still a boat
chuck it through some corners and watch it fail
Surprisingly, the F6 is not a bad handling car from factory. Doesn't give the same driving feedback when compared to a skyline though.
Anyone who says they handle like a piece of shit though should violently insert a pineapple into their rectum (looks at nick) : P
had to tell mortgage broker how much my car is worth for the loan application. Told him $7500 :( fml
haha
include the mods man... you can strip it into parts so technically it's worth the sum of the parts.
i listed my car as $50k on a loan app
i bet you would enjoy that lol :P
haha nice, I had to tell them the make, model and year of car. So they can always check up redbook if my head is too high up in the clouds :P
Can work as a double edged sword, as they could assume that it is more of a liability than an asset (if i keep pouring money into it!)
Now we play the waiting game....
We spoke about that in confidence Nick. Let's not do this in front of the children.
why cant you just accept the fact that i wanted to spice things up between us?
maybe have an extra person if needed?
why do you always cut me down so hard :(
http://www.stancenation.com/2011/02/21/teenage-dream/
So im thinking about selling my wheels... anyone keen $2400
Should consider losing the gts25-t sticker on the boot, did it on mine and looked 10x better without it
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
