its a nice looking car, but its still a boat
chuck it through some corners and watch it fail
Surprisingly, the F6 is not a bad handling car from factory. Doesn't give the same driving feedback when compared to a skyline though.
Anyone who says they handle like a piece of shit though should violently insert a pineapple into their rectum (looks at nick) : P
had to tell mortgage broker how much my car is worth for the loan application. Told him $7500 :( fml
haha
include the mods man... you can strip it into parts so technically it's worth the sum of the parts.
i listed my car as $50k on a loan app
i bet you would enjoy that lol :P
haha nice, I had to tell them the make, model and year of car. So they can always check up redbook if my head is too high up in the clouds :P
Can work as a double edged sword, as they could assume that it is more of a liability than an asset (if i keep pouring money into it!)
Now we play the waiting game....
We spoke about that in confidence Nick. Let's not do this in front of the children.
why cant you just accept the fact that i wanted to spice things up between us?
maybe have an extra person if needed?
why do you always cut me down so hard :(
http://www.stancenation.com/2011/02/21/teenage-dream/
So im thinking about selling my wheels... anyone keen $2400
Should consider losing the gts25-t sticker on the boot, did it on mine and looked 10x better without it
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
