why cant you just accept the fact that i wanted to spice things up between us?
maybe have an extra person if needed?
why do you always cut me down so hard :(
an extra person you say hmmmmmm.........HELLO!:D
cars up on carsales now waiting to be approved, think I can fetch 25k? if not will start stripping it off a few things haha
realistically, probably not.
Clean, full house build GTR's are selling in the 28-34k region lately.
For a stocker you're gonna struggle even for a '98
You might get the price, but you'll have to wait for it most likely... So it's the old argument of selling now for 2-3k less, or dealing with 6 months of muppets.
http://www.stancenation.com/2011/02/21/teenage-dream/
So im thinking about selling my wheels... anyone keen $2400
feature looks tits man!
what rim's/sizes you gonna go for?
EVO / V35 more so, but always loved evos.. id be looking at a evo 8 probably, but yeah need to sell my car first so could take a while. Want a newer car.
EVO 8 = Win!
http://www.stancenat.../teenage-dream/
Write up looks great Billy!
WHATS UP PLAYERS!!!
Man, where you been hiding at?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
