Nmh just dropped off my brothers r34. Wonder how it will go with a GTX3076r running on vapour lpg. Should be good
Is that the same turbo as yours?
Got a 2nd interview for this job woot, apparently this is a practical test I'm a little :s
Really want it so I can get back into modifying the car.
I have a dilema: I effing <3 Skylines, but I buy a ute to carry the bikes and it's pretty sweet as well.
Only problem is, now that I own it, when I drive I look at Jap cars and feel sick with envy and want to buy one. But I still own one... >_<
Will I never be happy no matter how many cars I own? lol.
welcome to grant's world, and i'm glad i'm only that crazy with pushbikes.. although well.... they were pretty expensive though..
Damaged the bits that hold the 2 leg bones together, and they were separating, so got a screw put in.
Surgeon told me I'm not allowed to drive or do anything for 2 weeks ffs, not sure how I'm supposed to go to uni....
sucks to hear that... i assume its the right leg then? take the cab for 2 weeks, or find a mate?
no...
left leg ;)
just not allowed to drive because it has to be 'elevated'
50 min cab ride to and from uni no thanks :P
ill make someone drive me XD
man you've 'sold' it about 10 times stop takling about it till car is gone money in yo hand
otherwise STFU it aint sold aint going nowhere.
cool.
3 times to be exact. Just hoping this dude isn't a time Waster..
Jeez your an angry man alex. Sounds like you need some gts4 sedan in your life :P
  • Nope 1
Alex is just saying what we are all thinking. You were the same with buying a car lol
grant
did you or your brother loose a camera?
ive found a sony cybershot in my car back area somewhere
has some farm pics etc on it then your 33 at deca
so i guess its yours ?
:D
looking for it ?
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
