in other news, work hadn't even STARTED my XD9's that i ordered 3 months ago, so i swapped the order for these:
fronts are 17x9+12 rears are 18x9.5+12
some folks gon love em, some gon hate em
They are very slow over there, you'd think they would have delivered them in a month.
Good choice, I had a look at those too but decided against it.
Just spoke to the nicest (and most annoying at the same time given I just wanted to get off the phone) lady at commbank....Rang up for credit card enquiries, and while she was sorting them out she was talking to me about her daughter, my house, her daughter wanting to buy a house, what furniture and appliances I need, the hours I work, how I sleep after a night shift, eye patches and ear plugs, and everything else you could think of....
[/size][/color]
I would rather the stocker, its got mad response. But blows its ass out after time.
You're not last either, Rob in the other black S2 is keeping the bottom warm at the moment.
Winton is 170kmh tops for me, but it is not sustained. Ie you're on the gas out of turn 15, then into fourth 100m down the road, then hard on the brakes 450m later.
Where as Calder, PI and Sandown you are on the gas for a good time. Though this all depends on how you exit the corner onto the straight.
send me the link of the classes and standings etc...
The stocker sucks, I was too slow to keep up with anyone and everyone.
Martin will have an update in this thread when he gets a chance to hit up excel.
The stocker turbo will net you 195-200, which is basically the power cap restricted by the fueling mods (215 in the case of my setup).
Once you tune the stocker it has a lot more bite over 4k.
Nah i'm skipping Winton so hopefully I can buy tyres in time for Sandown and a few other mods too.... as much as I really want to go.
I should write a list on what I need... something like this:
Tyres ~1000-1200
Radiator+Hoses ~200+100
Oil Cooler ~400
~$1500-1800
For a uni student. Starting my 4 week teaching rounds next week which means only 1 shift a week :(
Good work on changing wheels.
Fanta + Carlton Draught = Who knows.
How old was her daughter?
I'm thinking it's gonna be win...
At the moment I have some blue/grey 57max on the rears and with the red wheel nuts it actually looks pretty good! And the orange wheels are a better match than the bluey ones
It's amazing how much the nuts can bring it all together!
Tyres ~1000-1200
Oil Cooler ~400
~$1500-1800
Ah yeh hard being a student I've been there, still see if you can somehow manage to make it :D Winton is my favourite track :cheers:
Well if you sell your current rims $$$$?
See what happens when i'm a week out from Winton, my mind might change haha
I dont think I want to sell my rim anymore... haha might just get rubber for them and flare my rears
Can't be arsed reading back. Mohsen did you happen to have a guy in an S14 wave at you over the weekend? :D
ps. how was GOR cruise
I didnt go gor. Didn't really go anywhere over the weekend...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
