didn't you say you had buyers lining up now but didn't wanna sell it from under the guy off ebay?
murphys law
i hold it, he disapears, call other guys. they found another car
FFUUUUUUUUUU
http://www.youtube.com/watch?v=FkcJ2Qv3Nwc&sns=fb
mmmmm had a guy call today say hes keen as on the car, cash ready
told him i gave my word to the other guy but if it falls thru its his
always happens when your holding something
nah it doesnt kents just want what they cant have call him say hey man fell thru come buy it $100 he doesnt buy it
spose my $100 is still safe ?
hell i've even got an R33 turbo lying around here for it...
moe, give me your car
i got a nistune, 550cc sard injectors, hks2530 and z32 afm sitting next to me. Chuck it on the car, make it a track/drift car :P
Only catch is you supply the car trailer. deal?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
