I look 19 anyway, it doesn't matter how old i actually am...
AHAHA and seriously, the lecturer has been looking my way for awhile....
But then again, do you get people looking at you while having a root? if you dont, then you dont have to be worried getting seen with a 16yr old. Right?
Edited by xALmoN
i reckon that chick is pretty cute...
How does she rate compared to the one you're trying to hitch me with?
Crimes Act section 45 :thumbsup:
so many people thinking it's 18.. more slappers for us amiright?
Yup, more slappers for us ;)
My friends found this out the hard way...by losing a monetary bet to meeee :)
But I donated the winnings to a victims of sexual abuse charity in a feat of unselfish irony.
Of course, it is important to keep in mind that the age of consent changes to 18 if you have a pre-existing relationship of authority, such as a guardian / teacher / sports coach / employer.
Im not impressed by slappers and no I wouldnt touch her she looks fkn 12
I don't see the problem?
True, however picking up some sIut in your skyline doesn't really fall within the ambit of that section now does it? :whistling:
Wow, how did I miss all this underage talk?
Ric, can you clarify the rules for me? I've heard from some people it's 16 and others it's 18.
Got a 17 year old that may or may not be sleeping at mine on Friday night :P Need to know before then lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
