haha nice one Mohsen. Some troll hoarding all the sideskirts
i got one good one in white and a cracked (but repairable one in silver if you want em
cheers for the info.
Unfortunately I did have a pair of slightly damaged ones and it wasnt worth the repair :(
i see that appeal in a real hsv.
not a ss with a hsv body kit
That's what I figured too.
GXP = VE SS with a lip spoiler + HSV front guards, front bar and bonnet...
What's with the engine hood duel air scoops on the bonnet?
Air intakes or does the rocker cover need cooling?
f**kING HELL
I HATE KIDS
driving back from a mates house, AND SOME f**kING RANDOM KID COMES RUNNING INFRONT OF THE CAR. i slam the brakes and swerve right, justttt scraped a tree, front right corner of the bar, just a scrape but f**k im pissed off. should have just cleaned up the kunt.
Edited by Mohsen
f**kING HELL
I HATE KIDS
that's happened to me before, but both times were emo girls trying to commit suicide..
i know! bricks were shat!
gg today for me.
Was on left lane behind a car. All of a sudden a van on the right lane zoned out to what was in front of him. Traffic stopped in the right lane and when he realised he swerved onto the left lane. The car on the left lane next him quickly swerved to his left onto the side of the road. This all happened when it was pouring in rain.
I was behind the left car when all this happened. Scary bit is that I was planning on overtaking the car in front of me at the previous lights. May have ended up with a van in the side of me O_o
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
