Nah, it's been done. People have even squeezed them into the older (and smaller) AW11 model.
Having said that, most people tend to go for the V6 option and whack some turbos or a supercharger on. I knew one guy pushing 700HP about 2 years ago. Wonder what it's running now.
haha have that car on a dvd
doesnt make anymore power, it was just for quick response
So the Twin Supercharges would just give better low down response and a more even torque curve, yeah..?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
