On the topic of catch cans, I have heard good and bad things about them. Some people recon that the vapor helps to keep things lubricated. Where if u put the catchcan in it will take that away. Dunno tho, what are peoples thoughts on this
Speaking of which.
I keep seeing a white Lambo out the front of my work, Asian student gets out each time and goes into the student accomodation block across the road... lol.
I see AMGs and all sorts of other thumping cars and sometimes with P plates on them
It's seriously taking the piss @ reality.
That Asian student is my cousin.
Hopefully this asian dude has no appreciation of money :)
Other dude around here about 21 or so drives a late model lambo... His dad owns viking transport
His dad is my uncle, so yeah that's my cousin too bro.
Spacers are cheating, like a push up bra really
:rofl:
That is great!
LOL. I know. It was only 5mm though. Most people would say I was being anal, but knowing my rears were tucked in by 2mm just did my head in.
Really, so having the pipe work 10cm in, 10cm out. With for instance 100cubic mm of surface area for the oil to come in contact with. That is going to
perform the same duty as 45cm in and 45 cm out with 450cubic mm of surface area for the oil to come in contact with? Surly the more you can
break down the vapor the better?
but yeh maybe he is right, the air may not 'slow' down as such.
after 30 odd track days my can only has residue inside it and the intake pipe is clean.
yeah maybe this is one for mythbusters cause your idea is definately plausable and works well for you ..
its true, i never use a catch can when I sex
Haha, then that would be his sister i was talking to the other day, she drives a beamer and is smoking hot in a mini skirt and heels :)
Either way there are a million different ways it could be done.
eeerrrrr yeh wat thinking more like keeps the butterflys lubed not your wang
Negated by the fact the oil vapor is effectively lowing your octane ratting, thus causing or leaving you open to knock.
but isnt some blowby normal?? dunno guys im just saying i've heard arguments for and against have have nfi. I dont run a catch can atm, my cars not really modified to the point where I would need one.
:rofl:
That is great!
Even better, tell him to do some good prices on the stuff for me.
Is that how you know Jess?
The asian or the lambo dude?
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
