Connect a justjap / autobarnz / ebay can between the cam breather and intake pipe.
I made the hoses long to reduce the speed of the air so it wasn't just going to suck oil vapor straight out of the pipe. As there are
no baffles in these cans.
Im a bit confused by this pic mate, i couldnt see it properly on my phone but im home in big screen full hd now.
1. your catch tank is on its side which means if it was catching oil it would drain back down the line anyway
2. your radiator is croooked
Is this car smashed or something
Anyway heres where I ended up mounting mine..
Yes and dont forget somewhat powerful...heard a few stories of people that USED to work there..
Nobody messes with daddys little girl :laugh:
Sounds like you had quite an in-depth conversation with her...were you tuning her or something?
Yours?
It had a good life, it was certainly it's time.
Ah I love April fools. Don't you worry my motor is still smacking the limiter as hard as anything. You and Mohsen got sucked in LOL. Dw Mohsen actually messages me asking haha
only because i got worried :wub:
expecting a ride on the dyno day :P
normal people don't make April fools day pranks after noon.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
