Go to YouTube...type in "soccer".
Soccer players take dives, no shit. It's no different to 90% of high tackle/holding the man/push in the back free kicks in the AFL. They exaggerate or in some cases flat out fake it in order to get a free kick.
Sometimes fouls go unnoticed without the exaggeration, so you do what you have to do to make sure they don't.
alot of those might look like dives in soccer but you'd be surprised. go play competitively on grass surface then have someone's legs moving all around you while you're running with the ball. 8 times out of 10 you'll fall over even if no one touches you.
We pay the rego they don't. We get priority lol
fkn lol
So calling you a douchebag throughout the day makes you feel loved? Geez someone calls you honeybunny ONE TIME and it's going to be all *stalker alert* :ninja:
With some people, it's all about the tough love.
Problem?
Btw, think I used to see you on Edgars rd a while back
Nah man no pancakes last night, tbh I hate the pancake parlour they charge like $20 for some pancakes and icecream .... seriously .... it would cost them less than $3 to make that stuff. That and I was a broke ass sob last night had like $8 left in the bank till today when i get paid :S
in other news
this
http://www.news.com.au/breaking-news/scavenging-pensioner-cut-off-georgia-armenia-internet/story-e6frfku0-1226035145555
loooool
I always do. Work is so damn boring.
While I'm bored, if anyone has ever felt the want to anonymously abuse me, now is your chance. Give me your worst:
http://www.formspring.me/JDMR2
Edited by jezza boii
Yeah, but you've got balls Hamish :P Some people prefer to hide behind a keyboard and anonymously hang shit on me, to make themselves feel better.
I believe everybody should be entitled to that right, so I give it to them.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
