My mate had a motorcross track in his backyard...and a big f**k off digger thing to build the jumps/table tops etc...
Snapped the frame of my Pee Wee 50 there one day, welded it up and sold it for $600 (my mum bought it brand new for my brother for about $200 18 years prior)
make it stop
That guy has to be the ultimate troll. No way is that vid serious.
entry price?
dresscode?
hot girls?
15 if your on a list
whatever the f**k you want really, last week was jeans and a t, this week ill be fromal spec, but with crutches and a moon boot ;)
many many dubstep broad minded persons to be had
I'm pretty sure a nice T will pass at Jet Black, dress code was never that strict when I used to go. And we don't have to stay there if it's shit or if you wanna try elsewhere, was just a suggestion :)
I'm telling Alex to dress to impress for his own good :P Last time his wrinkled shirt made him look like a mass bogan lol.
I'm not sure whether to go for the wog look (tight white T and a cross) or wear a nice collared shirt with the sleeves rolled up. See how I feel later.
Probably meeting at Adam's around 7ish. So be prepared around then :) Will confirm times when he finishes work though.
Not every thought in your head should be reproduced verbally/electronically etc
You ain't gonna get poon typing phaggotry like that
lol I'm going wog tonight. Minus the cross.
Are you wearing white? Coz if you do, I won't :P Hate having matching outfits.
7pm it is. You have the address ;) I will shutup now because apparently it's offending Alex.
Hope to see you tonight Ric. Even if we just run into eachother on chapel for a quick chat.
wonton stock is a simple soybeans + pork bones + soy sauce + dried cuttlefish.
as for wontons.. i can't fold them properly!
That's only the easy part of the stock. :D
add in a few other little things and it becomes something totally different.
pfft, wontons are easy to fold. xD
But you tend to see most restaurants cheap out on the filling! >:|
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
