yup. miss that thing already :unsure:
on that note, was talking to a chick on teh cellular phone. my mates getting sus, im like, lols tims getting sus about this
her: oh whut does he think im your mrs?
me: yer
her: oh lollzz i probably will be mohsen, dont you think
me: probably not
her: ohh...
motherf**ker. she barred me on saturday for that >_<
Nah the laws of hard ball will always apply IMO, the only thing that changes is the words/language you use. He's doing it the right way...not telling them to f**k off, but suggesting they put more on the table because he's not quite enticed yet.
1968 was treat em green (weed) keep em keen.
This. Keeping in mind the phonecall one was supposed to be my +1 to the movies n shit. You know, I know she wants meh, she knows i want her, but just gotta let her know Shes going too quick.
Also, valentines day. Told her I'll pick her up from school and well go somewhere. Never even left home. She waited for ages.
And still all lovey dovey to me. *insert troll face*
And I literally punched a bitch in the mouth once.
Even when you treat them well they tell you to get f**ked
Zactly. For some girls (read: many), knowing that you want them is sufficient for their ego. *insert big empty space here, where the need to sleep with you for validation used to be...soon to be replaced by the act of masturbation*. Of course it does require them to find you acceptably attractive in the first place...but even if they don't, you can still fill a girl with sweet insecurity and try your luck at that?
P.S. agree with Jez, Moh...unless she took a shot at your nuts, in which case, open season on her face...don't be hittin them :domokun:
*insert big empty space here, where the need to sleep with you for validation used to be*.
On a side note to this..
My mum gave me a massive lecture the other night about sleeping with girls that I'm not dating. I tried to explain the concept of casual sex to her but she is absolutely insistent that the girls are doing it only to impress me, and that they're looking for a relationship.
Do you think this could be the case? The girls tell me they're dtf, but I guess women are always hard to read.
did everyone else miss that?
Depends on the girl and the situation / what is said between the parties. Some girls use it as a trap to try and get a relationship out of you (in the same way that a guy will use a relationship to get sex out of a girl)...some are genuinely after just a good time...
...some misread you totally, thinking that you proposed to them that night and have every intention of spending the rest of your life with them:
Huh? I just wanted to post the forever alone guy :mellow: But i do agree, "treat 'em mean" still has some merit
No. Mohsen is 18, it's ok for him to be preyin' on school bitches. Let's not discuss that old chestnut again!
Birds, I think you're right about that relationship trap. So many girls have tried that on me, and I never took a bar of it.
I think it's male-nature to lead them on a bit if they're playing that game, but I force myself not to do that. It's not worth all the bullshit involved.
Edited by jezza boii
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
