damn that sucks - who did you order through man?
I bought it second hand through my mate's importing business. There was like 20 exhausts on the shipment and mine was the only one that got damaged :P
My gearbox came in the same load and was fine too.
Imagine if it got damaged while shipping :P How shattered would you be? I ordered a Phoenix Power one and it got smashed up on the way from Japan.
Ordered a few things from streeter. Always packages well and had no problems
240rwkw, with 1/4 tank or less of 2 month old petrol (about 1/4 tank when it was towed in for work). Rang me 2day 2 ask what petrol I normally use 2 fill up. Maybe that has something 2 do with it also. There is a rattle from tailshaft (which I already knew about, could only just feel it periodically beforehand) or box (possibly does, doesnt feel the best always, just need it to hold up a little longer).
What should I do about the tailshaft? Should I go single piece .... or single piece after I no longer daily it, which I will be for a few months after getting her back...or stick with 2-piece?
been smashing nando's 1/2 chicken meals for the last month cos of their buy 1/4 get 1/4 free deal. split it with a mate for lunch and you have 1/4 chicken and half of seriously large peri peri chips for $6.50 each.
Some people like a loud/nice/mean exhaust note as well..
I sold a cat back not long after I bought and fit it because it was too quiet, almost stock sounding.
i like loud/mean sounding ones
although i kept the old 32 pretty quiet at the end, but the evo quiet loud now
loved your old exhaust though :)
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
