:rofl2:
Yeah after running a 12.6 basically stock as a rock I'm sure my bro is kicking himself for putting money into his GTST
But meh, thats just drags circuit is fun as well :D
[/inb4 flame]
Also Scott what about a 370z?
they are way to expensive they cost more than a E46 m3 way to much for a nissan in my opinion.
organising inspections/test drives on these for next week.
http://www.carsales.com.au/all-cars/dealer/details.aspx?Cr=11&R=10243687&keywords=&trecs=35&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__sid=12F5A5EA2F87&__Nne=15&__Qpb=true&seot=1&__N=1216%201246%201247%201252%201282%204294963593%204294963846%204294931739%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=0&R=9205456&keywords=&trecs=12&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__sid=12F5A5EA2F87&__Nne=15&__Qpb=true&seot=1&__N=1216%201246%201247%201252%201282%204294963593%204294963846%204294922300%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=12&R=9950012&keywords=&trecs=17&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__sid=12F5A5EA2F87&__Nne=15&__Qpb=true&seot=1&__N=1216%201246%201247%201252%201282%204294963593%204294963846%204294848651%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?__Qpb=true&R=10337452&keywords=&trecs=12&__sid=12F5A5EA2F87&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__No=0&__Nne=15&Cr=3&seot=1&__N=1216%201246%201247%201252%201282%204294967194%204294967179%20903&silo=1011
http://www.carsales.com.au/all-cars/private/details.aspx?Cr=4&R=10285615&keywords=&trecs=12&__sid=12F5A5EA2F87&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&__Qpb=true&tsrc=allcarhome&__Nne=15&seot=1&__N=1216%201246%201247%201252%201282%204294967194%204294967179%20903&silo=1011
Hey Kris, got the 31 back today. New turbo spools @ just under 4k rpm, the lag is not as bad as I thought. Pulls pretty damned hard from my short restricted experience today. Only tuned to 240rwkw, coz the clutch slips with any more. Didnt get a new clutch at the moment (only had the other one just over a year, havent punished it badly either) as I also need to get 25 gearbox & sort out something with tailshaft. The extra power makes the condition of these so much more obvious. I'm happy with it at the moment. If the lag gets to be too much of an issue, I'll put a smaller one in and save this for a dohc motor.
Can't seem to get a broken bolt out of turbo :/ mechanic's tried drilling it etc still won't budge.
He said he has tried the front pipe (jjr bellmouth) on with 5 of the 6 bolts done up and there is definatly no leak, is it okay to leave it like this? I have plans to hi-flow it through hyperflow soon, hoping they will be able to do something about it - will this be okay for a little while?
*insert scared face*
