my gf would think i was a fkn homo if i started straightening my hair, i have mates who straigten there hair i have no issue informing them they are homo's for doing so.
chemical straightening isnt permanent you know that yer?
Time spent straightening hair cuts into naptime!
And only occurs on weekends or afternoons after making the money. Don't think women don't have their priorities straight.... How can u buy shoes without money? :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
