haven't had a look yet but my ex used to do them at home so can't be too hard right?
hah yeh try to get ANYTHING done right before easter long weekend.. not happening.. seems easier to do it myself as usual, besides then when something is fckd I know what it is :) I don't have to go back in there 500 times to get them to fix their crap...
i have never seen a car u can change a pad without removing the caliper. Do they exist?
Look its pretty easy
remove wheel
undo 2 bolts that hold caliper on and remove
unclip and remove pads
push pistons back in, helps if you remove the reservoir cap
put in new pads and refit calipers
also, if I don't take it to a good friend.. they will *guaranteed* tell me I need new rotors, whether I do or not, AND I need to mount a speedboat onto my radiator fan because otherwise a wheel bearing will go flying out of the passenger footwell and take out the fuel pump on it's way..
If I even try to argue that logic a little bit then they become defensive real quick.. randoms are unable to do exactly what they're asked and only that.. guaranteed they will find an african elephant in an intake pipe that needs a new turbo to fix, because I'm a woman, what would I know??
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
