No time for it? :P I guess that's why you're always on the PS3 Kris :thumbsup: Get back into it man. Skinny kents like us need to pack on a bit of muscle.
I play at night man haha. I used to work 12-8. Go gym at 10am. Do cardio. Relax. Go to work. Straight from work to gym. Do weights. Then get home at 9:40 then die. Did that for a month then started going once a day
I need a break from all this talk of men and their hot steamy stupid sexy bodies.
haha hey it's all good, I don't mind :D each to their own and all that
nick wtf biggest waste of 10mins EVER..lol. His shirt might be always off but his pants are barely hanging on too. But at least it's better than the plumbers crack I saw earlier today :\
