hey billy, how did you put the milano in your car?
i'm thinking of grabbing one in XL if it will fit onto my current bride superlow rails
Yer I did, its nice and comfy for me.
Trying to source water pump... everyone is selling them for 300-400 in Aus, found this on ebay
http://cgi.ebay.com/ebaymotors/N1-WATER-PUMP-RB25-RB26-OEM-JDM-NISSAN-_W0QQcmdZViewItemQQhashZitem35b17b81f2QQitemZ230610928114QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Seems legit...?
great suggestion cept he doesn't do mechanicals doofus
I was just talking about the tune, I should of been a little more specific :P
and yeah i just went standard, looked good enough after having a play..
Get the standard pump from ericsperformanceparts (search seller) on eBay. Got a Nissan waterpump and Gates timing belt + Nissan idlers from there cheaper than anywhere else I could find online.
i dont rate em by bed performance complete packages.
and i dont do fuglies
so i mean all round quality, lets face it you aint gonna have sex forever gotta be more to it than that.
I do to an extent. The sex has to be reasonable. Plenty of dud's over the years.
Who says you can't be getting your grove on into ya 50's anyway.
Plus i'll be dead by time i am 60 anyway. Im sure of it.
That's a bit morbid and if im 50 unless the girl is mighty young Ill take my 3G non saggy bits porn
Ps get my pm?
Not really. I flog myself @ work, treat my body like shit (ie i dont sleep for 2 days @ time).
I dont think its really mobid. More so realistic. I'm having fun doing what im doing, so i dont really care for much more :)
Ye. IM closed... I'll get out there and pack it during the week on Wed for ya mate. :thumbsup:
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
