Saw a nicely done silver s2 33 at the gym the other day... Looks like they took inspiration from Billy's car. Nice stance and fitment, spoilerless, roof spoiler etc. I'll put a photo up when I get home from work. Only let down was I don't think they were decent jap wheels but they still looked alright ( I just prefer quality jap wheels on jap cars)
Had a massive dildo gear knob on it too lol
Saw a nice one in the purple-ish color last year, on decent looking jap rims (not sure what they were coz it was moving) but plates were DAGURU or something similarly gay...anyone got photos of it?
T & E VERTEX BODYKIT
MIDNIGHT PURPLE RESPRAY (MNP1/LP2)
JDM-SPEC SR20DET ENGINE
HKS GTRS BALL BEARING TURBO
HKS UPGRADED TURBO ACTUATOR
TOMEI PONCAMS (256IN/256EX, 11.5MM)
TOMEI ADJUSTABLE CAMGEARS
NISMO 740CC INJECTORS
WALBRO 255L/HR IN-TANK FUEL PUMP
Z32 AIRFLOW METER
APEXI POWER FC ECU
ARC SUPER-INDUCTION POD FILTER
ARC TURN-FLOW INTERCOOLER
HPI DUMP/FRONT PIPES
HKS HI-POWER CAT-BACK EXHAUST
OS GIKEN BUILT 5-SPD GEARBOX
XTREME 5-PUC HD CERAMIC CLUTCH
HKS HIPER D ADJUSTABLE COIL-OVERS
IKEYA FORMULA ADJ. CASTOR RODS (FRONT)
CUSCO REAR CAMBER ARMS
RAYS VOLK TE37 FORGED 1-PIECE RIMS
Fronts 18x9.5 +12
Rears 18x10.5 +22
DAGURU is a S14 with S15 front.
Looks like a S14A (Kouki) to me...
S14A fronts look so much better then S14 fronts.
Man i hate TE37's.
I'm partial. Jamies look great. Suit the r32 GTR to a tee. Prefer those gold ce28ns tho..
Also, overheard a couple kids at the shops talking about what cum tastes like, then one of them goes "mahmoud tasted his own cum, he Sed it was ugly"
Lol wtf
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
