The R32 may LOOK better to some, as this is very subjective but no denying the R33 is the better car. And the 32 Interior is aids duno anyone who prefers it over R33 interior.
Excited to get my car back tonight after tune (status).. base dyno run was 238rwkw so only 5 off the racepace dyno so pretty much spot on when you take into account temp / baro preasure etc. I'll be happy to see anything over 260rwkw anything over would be a bonus for me, hopefully a lot more power early in the rev range as well.
How much for an extra 120K/w at the wheels in a GTR that has the following already
Power FC (180kw)
Nismo CAT
Well, I have a exhaust, adjustable cam gears, and modded standard boost solenoid to run 14PSI - 233rwkw or 238rwkw depending on dyno, and now adding a power FC I'll let you know tonight.
If you want 300rwkw usually people go 2860s -9s and you will probably need new injectors / fuel pump to be safe. So in my opinion if your going to do turbos.. go big so your not disapointed with a little power gain for $$$$ (no point spending 5k+ for what ~40 kw)
My 2c.
This is true. And r33s have aircon that works
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
