Maybe he just wants to keep talkin to ya Juliette ;)
I must come across as too nice and friendly when I'm selling something. It hasn't just happened with selling cars, I've sold parts then ended up with 10 phone calls with questions afterwards. I've gotta start being a hardarse bitch from now on, might help?
Not sure why your complaining these people have paid good money why shouldn't you answer a few questions not like they are breaking ya balls everyday if I bought something and Hana few questions I'd expect answers
Tens pushing it but 3-5 is fine
If you regularly wash stainless exhaust tips they stay shiny...even the cheap stuff my Varex is made from is still shiny because I was it everytime I wash the car. My friend's Varex on the other hand, he let it go for a year and there's no coming back from that build up.
yeh my hks hi-power cleans up nicely except for the titanium tip, must not have been cleaned properly in japan and even steel wool cant clean it perfectly
Use quickleen stainless cleaner. We sell it at 30 bux per kg. Non corrosive, lasts for ages, not very messy. Acts like a cut and polish. I'll bring some on the next meet.
Cleaned up the exhaust on the r32 well.
On another note, my mate vacuum sealed my money hahaha. (he's a butcher, dropped the car to his bro and went to get teh $)
Took ages to open
Yeah but some of them get creepy after they're finished with questions related to the product. As far as I see it you ask questions before you buy a product, not after it. I certainly don't pester people I buy items off after I've received the item.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
