Half year wait for import? Is it that bad these days?
My Soarers came in 6 weeks a couple years ago. And they were held up at the wharf for quarantine.
EDIT: My bad, forgot about the liberal use of geiger counters at the moment.
yeah its out of reach. i like the evo 8 and 9's, at the dealer they had the evo 8 MR for 39,000 not including on road costs and yes i could of bought it but thats way to expensive considering i just missed out on one that iron chef imports had for 32,000. he said he has another evo 8 that he is listing soon so i sent him an e mail.
your getting a EVO on top of owning a GTR right? your not selling the GTR right? am i right?
Killed in a Mansion! WTF so he got down from the mountain! So he has people still in the hills fighting for what? Now the leader is gone! Is he now a matyr did he inflict damage in his death?
Where is the rain of nukes he promised?
Duke Nukem Forever release date September 2011
In 4 years when I'm licensed to buy the gas
fuck off. in 4 years the ceffy will have been scrapped for parts by some habib that ploughed it into a bus stop thinking he was a drift superstar.
How come you bitched out on words with friends? Couldn't handle my scrabblage? I demand a rematch!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
