That was awesome Birds!!! Pull out that dance move next time we go out! :thumbsup:
Btw, in regards to your event; Friday is going to be a bit difficult but I'll try and get down there. What are you doing on the Saturday? Coz I'm pretty keen to celebrate with you.
Edited by jezza boii
Reasonable. But most people I know have their pretty stock r34 gtt coupes insured for 20k.
but u have to actually be insured to get that much...
12k is better than the nothing ucould be getting
Couldn't sound any gayer LOL
Sure?
Btw, in regards to your "doo"; Friday is going to be a bit difficult but I'll try with all my heart and get down there. What are you doing on the Saturday? Coz I'm pretty keen to celebrate upon you.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
