23kg difference. That's the weight of my youngest brother (minus 5kg). Can definitely feel it.
Weight reduction I couldn't feel: Foglight removal, shaved aerial, lightened headlamps etc.
I reckon about 20kg is where I start to feel it. It may be my imagination though, but I swear I can.
And no, I take them to Nandos coz I'm so baller :D I make minimum wage c*nts lol.
Edited by jezza boii
You car is a ttop ye?
Actually don't even answer that, no point as 20KG is less than 1.5% of the cars weight.
You are tripping if 20KG makes a difference.
100kg (8-9%), noticeable. 20kg (1.5%), not.
It's your own crazy mind making excuses for ... well... fk knows what.
Do you take chicks to Macca's for dates too?
isn't that what everyone does?
lol my gf suggests we go for kebabs most times. f**king keeper
as for the weight saving thing lol fill up your tank man
not running out of fuel in the middle of nowhere > shaving 0.0003 seconds off your highway time
I said 3/4 is the max I've ever put in. It normally sits around 1/4. I put in $30 when it gets close to empty.
Also if it's expensive then I'll only put in about $10 and wait for the price to go down. I only put in $30 if it's cheap.
Weird system but it works for me.
EDIT:
Lol @ tyre/spare jack..... I removed my spare tyre and tool kit the day I got the car :P
So you live life a 1/4 tank at a time?
why do you want a sunroof anyway?
So I can tan on sunny days :D
And Kris how fun is it.. funny when you have no intention of racing but they started it all :P
I'm saving my pay for other stuff.. don't see the point pouring it all into the car I mean I got a PFC and tune so what ~$1500 I mean I can notice a bit of difference but was it really worth it? kinda thinking of just leaving the car now and not spending ~10k on turbos and shit.
TL;DR: I'm poor and can't afford a full tank of fuel.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
