I will punch you on the vag if you autotune yourself Jizzy.
Punch me in my hypothetical vag then. I've never released anything without autotune. Neither has any artist/band I've seen recorded in the past 4 years.
Even the best vocalists in the world use autotune now. It's industry standard.
I'm talking about graphic autotune. Ability to tighten up certain notes manually. Not a plug-in that runs constantly through the whole song.
Alex I saw you looking at me haha
Water pump and timing belt done... Drive my car home, open door and there is a strange ticking noise coming from the engine bay... Any ideas?
Could be the bearings / belt being very tight - my car sounded a bit different after I got mine done as well I think but nothing too bad.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
