you sound like a fkn 16 year old horny little kid who comes in here and brags everytime a girl walks with 8kms of you. it was like a broken record 20 pages back and your still going.. its really sad and frankly i dont think anyone hear gives one bit of a fck about you and your knob and its travels.
i have sex everyday... and?
jus sayin.. dont take it all personal either we got sick of grant and his car whingers to.
Bags of sand, amirite?
Oh excellente!
trader feedback go!
whats that? and how
nah man just ya know, get over ya self. Can't stand shit talkers on any subject. Not saying he is lying but to me its still shit talkin when ya talk yaself up every 2 seconds.
whats that? and how
"Excellent product, made me want to touch myself in sensitive places yet unexplored on my body. Ash is a pleasure to deal with, and short of giving me a reacharound and a cold beer on completion of the deal, could not have done a better job of making the transaction smoother."
copy and paste that.
hahaha
i cant afford any more warn status. :whistling:
theres a good korean bbq place opposite vic market, called hallah pretty cheap too :)
I used to bring my hotplate + stove set over to my friend's place and then prep our own dishes..
There's like 3 branches opposite vic market, one of them has really cute korean chicks in them..
